Cannot enable "snap" for imported PDF in R2020
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
HVAC-Novice
7237 Aufrufe, 4 Antworten
I have PDF imported to use a tracing background. The check box for the "enable snap" feature is grayed out.
Revit version: R2025.4
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: HVAC-Novice
Because it is a raster, not a vector PDF?
Nachricht 3 von 5
HVAC-Novice
als Antwort auf: ToanDN
You are correct, this PDF is scanned from a paper plan.
I tried with a PDF that I had generated with Revit (Vector Processing) and it "un-grays" that check mark and I can trace by "picking lines".
Assuming most older plans are scanned, this won't really help me. The scanned copies are not perfect anyway (rotated by 0.347° etc.). So I guess I will have to just manually trace.
Thanks for your help.
Nachricht 4 von 5
DDD-Greg
I am also having the same issue not being able to enable snaps for a pdf file in Revit 2020. I am following a training video where the trainer imports a raster door image from a website and he is able to enable snaps and then scale. Not sure why I can't as I have used the same file from the same website. Still snaps are grey'ed out? Any Ideas? thanks Greg D.
Nachricht 5 von 5
nabo_raymond
Hello
I've watched some videos on youtube where they have able to snap a "RASTER IMAGE"
