There is no grabber at the top of these stairs. There is usually a grabber that I can drag to change the stair length. However, with the landing attached, it goes away:
You can see the bottom grabber/arrow, that should be at the top as well.
I would have thought the grip arrow will be at the top of the top flight (after the landing)
Might be easier to do in plan.
Same here. Only the two points (blue dot and blue arrow) at base. Don't those alone work for you - in Elevation/Section View?
Edit stair, remove landing, grip editing runs to add/remove steps to runs, add landing.
just delete the landing to adjust the stairs
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
Autodesk Certified Professional
