Cannot duplicate wall
4 ANTWORTEN 4
Nachricht 1 von 5
Szigeti.Eduard
471 Aufrufe, 4 Antworten
I try to duplicate a concrete wall and every time I try to rename it I get this error. "A serious error has occured. It is strongly recommended that you use Save as to save your work in a new file before continuing". I do this and nothing happens.
Does anyone knows how to solve this problem?
4 ANTWORTEN 4
Nachricht 2 von 5
Avaris.
als Antwort auf: Szigeti.Eduard
Probably you, or a colleague is not on the latest built of your version of Revit. Could you check that?
Nachricht 3 von 5
Audit the Project.
...what method are you using? You use selecting a wall already placed in the Project and trying to duplicate it, or selecting a Wall Type in the browser and trying to duplicate it before placing it?
Nachricht 4 von 5
Szigeti.Eduard
als Antwort auf: barthbradley
I tried both ways and I still received the same exception
Nachricht 5 von 5
Szigeti.Eduard
I had to reinstall Revit and now it works fine.
