Cannot Delete Object
Hi, I've found a problem whereby I cannot delete a fridge that has appeared outside my building.  I downloaded the file from RevitCity as part of a kitchen.   Loaded the kitchen into my project and then noticed that a second fridge had appeared.  I am not sure when it appeared though.  I cannot delete it - right click on the model and the delete tab is greyed out.
I have checked the actual family and there isn't a second fridge showing, plus I've also noticed there is a difference in the aligning of the worktop from the family to the project.  If you look at it in my building the worktop is slightly away from the wall yet in the family plan view, the worktop is algned with the rear of the fridge.
Any ideas why?
Karol_Piroska
I tried to load that into a new project and there doesn't seem to be any issue with the family - aligned and no second fridge
Alan.johnson1970
yeah same result, no issue with family. Must be in your project.
AJ.
Sahay_R
Can you share the file that shows the duplicate fridge?
Is the fridge hidden, pinned,? Are your Select settings right? See screenshot below -
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
chrisplyler
Family works as expected when I load it into a new project. Alignment is correct and there is no second fridge.
