Cannot cut ceiling family at wall intersections
9 ANTWORTEN 9
Nachricht 1 von 10
eloise.banwelljarvis
562 Aufrufe, 9 Antworten
Please help
I have been trying to cut a parametric ceiling baffle system family at my walls and windows but cannot manage to do it. I have tried void forms and the cut tool but it will not work.
It is rendering outside the windows and i cannot shape it to fit anything other than a square.
9 ANTWORTEN 9
Nachricht 2 von 10
Jason_S
als Antwort auf: eloise.banwelljarvis
Looks like the family created is a Generic Model Family.  If using void forms (Modeled in Place), you will need to make sure it is in the same category as the item, you are using it on.
Nachricht 3 von 10
Use a SOLID mass to cut it.
Nachricht 4 von 10
als Antwort auf: Jason_S
@Jason_S Just tried this but it says there is no geometry to cut :enttäuschtes_Gesicht:
Nachricht 5 von 10
als Antwort auf: ToanDN
I've created a solid mass where I want to cut but it won't allow me to select the solid mass when I select the family with the cutting tool :enttäuschtes_Gesicht:
Nachricht 6 von 10
Hi @eloise.banwelljarvis
Thanks a lot for posting your question to the forums!   I am tagging @SteveKStafford @jay_colcombe, who may be able to assist.
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Nachricht 7 von 10
Jason_S
Sorry, about that.  I just realized the image you shared has the family you created highlighted.
Instead of using the family you created, try using sloped glazing.  You can create profiles that represent your baffle and apply it to the mullions under edit type.
See attached.
Nachricht 8 von 10
Cut geometry, select the family first then select the solid mass.
Nachricht 9 von 10
Thanks a lot for posting your question to the forums!   Have the solutions suggested by @Jason_S @ToanDN  helped with your issue?
Jonathan Hand
Nachricht 10 von 10
eloise17053
als Antwort auf: handjonathan
Unfortunately none of the solutions worked for the family I was attempting to cut. I ended up photoshopping the object out of my renders in post
