I have an issue creating a local file. If it's me to create the file central, I can create the local file but my coworker can not and opposite, If it's my coworker create the file central, he can create the local file and I can not. Does anyone have any idea how to fix this?
Thank you so much!
Minh Nguyen
Gelöst! Gehe zur Lösung
Gelöst von SteveKStafford. Gehe zur Lösung
Make sure your path to the central file is defined in the same way (networking language) as each other. If the path Revit sees to the central file is "different" for both of you then Revit won't regard your central file as the same file and you'll end up in this "loop". That all assumes you're not working via BIM360 hosting.
Steve Stafford
