Cannot create central file from Revit template, please help
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
natalya.belenko
603 Aufrufe, 2 Antworten
Hello everyone.
I do need a help from Revit gurus, please.
I cannot create the central model from the AR template file for some reason (though before it was not an issue): it allows me to Save As only the same template file.  I would trash this file, but was working on it for 2 weeks already in order to create a useful template for the company with lot of info and elements in it.
Would greatly appreciate your suggestions!
2 ANTWORTEN 2
Nachricht 2 von 3
shellyk
als Antwort auf: natalya.belenko
You can't create a central model from a template file, only from a project.
But no worries' it's an easy fix-
1. Save the current template file
2. Open a new project, loading the template file you just saved
3. create a central model from the new project.
Good luck! and don't forget to mark this as a solution (:
Nachricht 3 von 3
natalya.belenko
thank you!!!
