Cannot copy element because of the "Relationship between elements"
1 ANTWORT 1
Nachricht 1 von 2
1546 Aufrufe, 1 Antwort
Dear All,
Revit independently creates relationship between elements, which are on the same Ref. Level.
In my case it is Wall element "related to" Floor element, in the way that wall element cannot be copied (see image) and removal of floor element removes all wall that are "related to it".
Does anyone knows how to get rid of this "relationship" ?
1 ANTWORT 1
Nachricht 2 von 2
SteveKStafford
als Antwort auf: Anonymous
Copy to Clipboard is quite different from Copy. If you want to place another instance in the same plan view (which is based on a level) use Copy. If you want to "copy" and then "Paste" a wall, for example, to several Levels then use Copy to Clipboard.
If an element is hosted, like a window, then the host must be included in Copy to Clipboard.
What specifically are you trying to do?
Steve Stafford
