Hi All,
I was trying to do a sweep with profile below. I have closed edges but cannot the message keep popping up that I would not be able to do the sweep. Apart from sweep, any other ideas to make the "fillet corner" form? Thanks.
Solved by martijn_pater. Go to Solution.
Maybe add a small line to the circle piece, but why not a continuous sweep...
I was thinking on the inside he'd have a 0 length sweep as is, trouble is the hard edge corner or you'll end up with a mitered corner? So you probably need a small filleted corner there...
edit: basically the radius of your sweep can't be equal to the radius of the profile
