Cannot check Category objects in Visibility/Graphics Override dialog
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
3333 Aufrufe, 6 Antworten
When I open the Visibility/Graphics override dialog, I cannot check a visibility object on or off, the checkboxes are inactive, see screenshot attached.
Does anyone have an idea where to fix this problem?
6 ANTWORTEN 6
Nachricht 2 von 7
zemeraloni
als Antwort auf: Anonymous
Hi @Anonymous
You are probably on an active template wich lock the vg setings.
You should either remove the template (select none) or set the model override off. see attached images.
Nachricht 3 von 7
looks like the checkboxes are there, but split in half...
Make sure your graphic card drivers are up to date and if they are you may have to disable hardware acceleration in Revit Options.  (Big R...Options...Graphics)
Nachricht 4 von 7
What is your screen resolution?
Nachricht 5 von 7
Thanks, your input is appreciated.
I have a good graphics card (Nvidia GeForce GTX 1050GTI).
I turned off Grahics accelleration as suggested, but this did not make any difference to the check boxes.
Could you advise any other possible cause?
Nachricht 6 von 7
als Antwort auf: ToanDN
Thanks for responding.
Screen resolution is 1920 x 1080 (recommended)
Nachricht 7 von 7
bim2UY2Y
als Antwort auf: zemeraloni
Yeah, It work.
