Hello
I'm getting this error "Cannot assign or add 100A to Circuit. There is no assigned distribution system for 100A". I'm super lost here...
*I'm using a normal architectural template for this project. I added an Electrical View template. And I changed the "voltage definitions" and "Distribution Systems" 😞
Solved by alfredo.medina. Go to Solution.
Solved by rudi.roux. Go to Solution.
Hi @Pantaleon02,
Hope you are well!
You need to make sure of the following 3 things:
You can use the images below to reference from:
I hope this helps!
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome ⇘
I did a test, based on the image you posted. This should work with the panel and distribution systems that you have, as shown below.
Perhaps the distribution system was not assigned to the panel yet when you tried to assign the circuits to the panel, as @rudi.roux said?
