cant make stair in Revit 2024 from level to level, its happening with my student who use Revit 2024 only.
Only way to avoid it by chang the top leverl like -0.001
[ The subject line of this post has been edited for clarity by @handjonathan Original: REVIT 2024 PROBLEM]
I can't read what the base level is? It's a simple stairs, so there should be no problem.
Ok, so the levels are ok and the floor height is 3.12 meter. What does the error message say if you click the Expand button? And are the 'Calculation Rules' switched on? If so, switch them off.
