Cannot add door on curtain walls
8 REPLIES 8
Message 1 of 9
mina_saracoglu
374 Views, 8 Replies
Hello. I used curtain wall in my project. However, I cannot add a door. I watched a few videos about this. I tried to add the doors for the curtain wall from the Load Family section, but it did not work. when i tried to it said cannot load family files. Can you help me?
Tags (2)
8 REPLIES 8
Message 2 of 9
Insert Tab=>Load Family
Not Architecture Tab=>Door=>Load Family
Message 3 of 9
in reply to: mina_saracoglu
Do not use door button from the ribbon. Load a curtain wall door family in your project, select a curtain panel, unpin if you see it's pinned, and change it to a curtain wall door type.
Message 4 of 9
Okay thanks now I'm gonna try. I'll let u know. Thanks a lot
Message 5 of 9
mina_saracoglu
in reply to: ToanDN
I'm gonna try this too rn. I'll let you know thanks a lot
Message 6 of 9
mina_saracoglu
in reply to: ToanDN
Hello, I tried as you said but it still didn't work. Where else could the problem be?
Message 7 of 9
When i tried this it didn't work. I clicked the curtain wall panel too. But nothing happened.
Message 8 of 9
You're still not loading family correctly.  I can clearly see that you're trying to do it via the Architecture Tab's Doors.
INSERT TAB=>LOAD FAMILY
Message 9 of 9
Forma Design Contest
