Hi
When I exporting my analytical model to DXF file to Autocad, each beam in Revit splits to 3 beams in Autocad.
can I change it that ?
Gelöst! Gehe zur Lösung
sorry, did not find my answer there.
my problem that each beam divided to 3 segments. how can I change it to 1 segment?
I don't think you can make 3 into 1. But you can change the Export options to make them the same color by Layer.
In Autocad, I used the command "OVERKILL"
it removes spare nodes from the model, and makes 3 straight beams into 1 beam.
