cancel start segment and end segment in beams when exporting
5 REPLIES 5
586 Views, 5 Replies
Hi
When I exporting my analytical model to DXF file to Autocad, each beam in Revit splits to 3 beams in Autocad.
can I change it that ?
5 REPLIES 5
in reply to: barthbradley
sorry, did not find my answer there.
my problem that each beam divided to 3 segments. how can I change it to 1 segment?
I don't think you can make 3 into 1.  But you can change the Export options to make them the same color by Layer.
In Autocad, I used the command "OVERKILL"
it removes spare nodes from the model, and makes 3  straight beams into 1 beam.
sebasordonezm
Could you explain in more detail, please
