Cancel multi-storey revit 2021
6 ANTWORTEN 6
Nachricht 1 von 7
1457 Aufrufe, 6 Antworten
Hi
I am trying to cancel the multi-storey stair (MLT) that was created- no tool exist to do this!
How can it be removed?
Another thing, I cant copy of of the systes, stairs aaisde or to other levels (mainly the reason I want to disable the MLT)
Beschriftungen (3)
6 ANTWORTEN 6
Nachricht 2 von 7
alan_eu
als Antwort auf: Anonymous
On a elevation or section view, select your stair, and click on connect button. So click on disconect and select your levels and hit the confirm V icon.
Alan Araújo EESignature
Bee1ColabInstagram Alan Araújo RevitBee1ColabGrupo Whatsapp
Usuários do Autodesk Community:
  • Se a resposta resolveu o seu problema, clique em Aceitar como Solução! isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou :leicht_lächelndes_Gesicht:
  • Manda um alô nas minhas redes sociais com +600 vídeos de de Revit/BIM, Templates e conteúdos semanais! Gratuitos! :leicht_lächelndes_Gesicht:
Nachricht 3 von 7
als Antwort auf: alan_eu
Doesn't work to cancel the multi storey effect. They kind of stay in a group manner
Nachricht 4 von 7
alan_eu
Could you send us a pic?
Nachricht 5 von 7
the last stair is still in multi storey
this is what i want to cancel
Nachricht 6 von 7
syman2000
Saddest part of this multi-storey stair is you cannot convert it back to stair once you add multi level. So your choice is delete it and start over. One way I find it working is to create one flight of stair, group it and copy it up.
Nachricht 7 von 7
ennujozlagam
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2021/EN...
