Hello, try to cancel the dwg file but can't do it.
How can I do please?
Not unable the visibility, cancel.
Thank's
Gelöst! Gehe zur Lösung
Gelöst von aleksei.tkachenko. Gehe zur Lösung
Hello
What are you mean with "Cancel"?
You can simply delete dwg if you unpin them in advance.
Do you want to delete layers?
If you select the DWG, you should see an option to delete layers.
Yes, but you can also go to "Manage Links", find your dwg there and remove it from the project.
Why if now reinsert haven't the same link in "manage link"?
When reinsert also say coordinates between dwg and model not coincide.
Thank's
Probably you imported dwg instead of linking it to modell. Imported dwg does not appear in "Manage Links"-tab. You can find them into "Visbility/Graphics" -window under Imported Categories Tab.
