Can you sketch this monolithic stair? I couldn't.
14 ANTWORTEN 14
GELÖST
Nachricht 1 von 15
dbroad
1062 Aufrufe, 14 Antworten
How can this stair be modeled in Revit using the stair sketch?  I want it to be 21" high. I do not want it to include the porch platform.  I've tried everything I can think of.  Then I just punted and used the component model in place with a predefined profile defining the three step edges as a sweep profile and and extrusion as infill.
Actual In-place stairActual In-place stair
Architect, Registered NC, VA, SC, & GA.
14 ANTWORTEN 14
Nachricht 2 von 15
martijn_pater
als Antwort auf: dbroad
The in-place method doesn't suffice?..
Nachricht 3 von 15
Plenty of approach: model in place with sweep profile like you did; floor with slab edge; stair.  Here's using Stair tool.
Nachricht 4 von 15
What's wrong with assembled stair?
Nachricht 5 von 15
dbroad
als Antwort auf: martijn_pater
@martijn_pater Here is the result of the component method using sweeps and adding a material. It takes longer but it works.
Using sweepsUsing sweeps
Nachricht 6 von 15
dbroad
als Antwort auf: barthbradley
@barthbradley , When you say assembled, do you mean using the stair sketch tools or modeling in place?  If you sketched it, I would sure to know how you did it.  Your stair looks good.
Nachricht 7 von 15
dbroad
als Antwort auf: ToanDN
@ToanDN I literally tried for 4-6 hours trying to use the stair sketch tools and fiddling with the monolithic nosing settings.  Couldn't get anywhere.  It kept either refusing to make the stair or when it did, the stairs had odd artifacts and sloping treads like it sliced it off with a knife.  Your stairs look good.
Nachricht 8 von 15
Yes I used Assembled Stairs.  Edited properties and unchecked Riser and changed the Tread Thickness to 6 171/256" (the Actual Riser Height). Then added my Brick Nose and changed the Material of the Tread to Brick.  Bada Bing!
Nachricht 9 von 15
Oh! I forgot. I deleted the stringers as well. You could also change the Properties to omit the Supports (e.g. set to "None")  as shown:
Nachricht 10 von 15
You could also do it this way -- with the Riser and Tread the same thickness as the brick unit:
Nachricht 11 von 15
dbroad
Thanks. I will try to repeat those techniques this evening.
Nachricht 12 von 15
Okay, sorry for hogging your thread, but I got one more for you.
Using a Support for representing the foundation under the brick:
Nachricht 13 von 15
It's a few simple settings to a monolithic run.
Nachricht 14 von 15
dbroad
Thanks @barthbradley . Sketching an assembled stair that looks monolithic is a lot more reliable than sketching such a stair as monolithic.
Nachricht 15 von 15
You're welcome, Doug. Thanks for the shout out.
