Can you set dimension default to snap to wall face instead of wall center
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
David125
369 Aufrufe, 2 Antworten
I'm on Revit 2023, is it possible to set dimension default to snap to wall face instead of wall center?
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: David125
Additional Settings=>Annotations=>Temporary Dimensions Properties
...Or are you referring to this:
about Automatic Wall Dims:
Help | Add Aligned Dimensions to Walls Automatically | Autodesk
Nachricht 3 von 3
David125
The second one. Thanks.
