I have a 9 story office building that we are renovating. We are 90% done and the client has decided they want to reorder the phasing. Is there any way to reorder the phases sequentailly? In this case I need to move the 4th phase between the 8th and 9th phase, see picture.
Solved by Karambaki. Go to Solution.
Nope Actually you cannot re-order in an easy direct way,
Create a tmporary phase after the 8th one,
And move all the elements from phase 4th to the newly created one, then combine the 4th with the previous one of the next one it wouldn't matter,
You can use phase filter to help you out in moving the elements from phase to another.
After finishing up, rename the phases the way you want.
NOTE* You'd need carefull planning and understanding of the project if your doing such step
Greetings,
Karam
