I drew my setback lines with Model Lines, and I tried to put dimensions on them.
Does dimension command not work with Model Lines?
Does it only work with Detail Lines?
Gelöst! Gehe zur Lösung
Gelöst von hmunsell. Gehe zur Lösung
dimensions diffidently work with model lines. Are you sure the dimensions are not turned off in the view settings? try picking the Reveal Hidden option....
Howard Munsell
Are you sure you are dimensioning on a work plane parallel to the work plane that the Model Line was drawn on?
Thank you for letting me know that dimensions work with model lines.
I drew my model line again and the dimension command worked. Thank you!
I thought about your comment. I understand. But I wouldn't question the work plane since they are all being drawn my "site plan" floor.
Actually it was badly worded. I'm envisioning you trying to dimension between parallel lines and your dimension won't snap to one or both of them, so I was asking if you were sure the lines are not "skewed" to the view.
Slightly off axis:
@Anonymous wrote:But I wouldn't question the work plane since they are all being drawn my "site plan" floor.
FWIW:
Site Plan View. Two Model Lines seemingly the same length, yet not.
Both drawn in Site Plan, but on different Work Planes.
...Catch my Vegas act. I levitate things too.
