Can you move elements from a group in a different workset from the group?
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
parkside125
347 Aufrufe, 3 Antworten
Hi guys,
I have some facade curtain walls and precast elements in group called facade. I'd like to move the precast elements to a different workset but still keep them grouped. Is that possible? It seems that worksets can only be associated to the whole group itself and no individual elements
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: parkside125
No. Everything in a group is the same workset as the group itself.
Nachricht 3 von 4
parkside125
als Antwort auf: ToanDN
I see. I guess the only solution is to remove it from the group and put it on a different workset?
Nachricht 4 von 4
It depends on why you need to separate them into different workset?
