I have a detail which I'd like to call out on my sections. I would like the callout to have 4 notes: one that has nothing, one that says TYP., one that says SIM., and one that says SIM. OPP. When I try to duplicate drafting view properties and add this info to the reference label value, it changes all the other callouts referencing that detail to the new one. How can I keep them separate? Thanks.
The same callout is TYPICAL, SIMILAR AND OPPOSITE HAND at the same time?! how does that work? Usually it is either or!
The reason they are all changing is due to the fact that reference label is a view/type property and not instance, hence all callouts referencing the same view will receive the same label...One way around that is using dummy callouts
