Can you dimension to the center of a filled region box?
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
1537 Aufrufe, 5 Antworten
Hi all,
Wondering if anyone knows how to dimension to the center of a filled region box. I've tried tabbing but it doesn't snap to the middle. Is there any way I can get it to? Thanks
Beschriftungen (3)
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
Split a segment of the filled region boundary sketch and you can dimension to that point.
Nachricht 3 von 6
What do you mean by "filled region box"?   Sounds like an oxymoron. Region + Box.
Got pictures?
Nachricht 4 von 6
als Antwort auf: ToanDN
Thank you that works. Is there a way to get the CL of the dimension to show?
Nachricht 5 von 6
I have a detail component family with absolutely nothing except the two center ref planes.  Place it in project and dimensions to it will show centerline pattern.
Nachricht 6 von 6
RDAOU
If that is part of the routine stuff you do, you might want to consider modelling the Filled regions as detail component. This way you do not need empty dummy families and split boundaries
