Can you convert CAD files to detail/model lines?
6 ANTWORTEN 6
Nachricht 1 von 7
StellarBeorn
564 Aufrufe, 6 Antworten
Sorry if this question has already been posted, I couldn't find it.
I have a very large imported .dwg file that I need to build a floor plan on. So far I can only think of clicking on each individual element to convert them into lines, but is there an easier way to convert elements of a .dwg file to detail/model lines? I've attached a screenshot below.
Tags (3)
6 ANTWORTEN 6
Nachricht 2 von 7
RSomppi
als Antwort auf: StellarBeorn
I hope you linked the file rather than imported it.
Use Revit walls, doors, windows, etc. to trace over it. Converting it to native Revit 2D elements is a waste of time. If that's all you need, just link the .dwg without converting it.
Nachricht 3 von 7
EATREVITPOOPCAD
Linking is typically better than importing, and if you want to trace you should do what @RSomppi said.
To answer your question though it is possible to import DWG file into Revit and convert it into Revit lines
  1. Insert Tab -> Import Panel -> Import CAD
  2. Select the imported DWG in any view
  3. A Modify tab will pop up
  4. Hit Explode
The definition of insanity is doing the same thing over and over again and expecting different results
Nachricht 4 von 7
So basically, you want to convert AutoCAD elements to Revit elements. No can do.
Linking/Importing makes no difference here and Exploding CAD in Revit is generally a no-no.
Nachricht 5 von 7
EATREVITPOOPCAD
If the CAD file is just lines, and you would like to transfer over these lines to Revit, what's wrong with importing & exploding?
Nachricht 6 von 7
als Antwort auf: EATREVITPOOPCAD
I'm not saying it's wrong, per se.   We do it around here for family creation mostly.  It's generally a no-no to Explode in the Project. It introduces a lot of crap that needs to be cleaned up and/or managed.   It's not a seamless translation.
Nachricht 7 von 7
syman2000
I wouldn't explode CAD because Revit treat each line as an object. I would link it as a reference. For hatch, you can download from here
https://www.revitcity.com/downloads.php?action=search&keywords=aggregate&user_name=&sort=score
