Can we use Revit Checker to Check if an element is mirrored?
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
wezpb
1227 Aufrufe, 4 Antworten
Question is as per the title....Can we use Revit Checker to Check if an element is mirrored? if yes how do we set this up? if no, is there another way to check this?
NOTE: i did find an article that had this check in revit (https://help.autodesk.com/view/RVT/2017/ENU/?guid=GUID-EB31DE20-E894-4D5B-B0F0-4E7F04030786), but this seemed to to be for an old version and i could not figure out how to do this in the newer versions of the checker/Revit....Currently required for Revit 2019 onwards
Any help would be greatly appreciated.
4 ANTWORTEN 4
Nachricht 2 von 5
s04049
als Antwort auf: wezpb
Nachricht 3 von 5
wezpb
als Antwort auf: s04049
Thanks, but does this mean that you cannot do this in the Revit Checker anymore?
Nachricht 4 von 5
RDAOU
@wezpb
Dynamo is an alternative to "Model Review" (A.K.A Model Checker as of Revit 2021 onward) ... You can still check for mirrored elements using the Latter
  • The link to the article you have posted is for Model Review Add-in. This Addin is available for Revit Versions up till 2020. See GIF Below on how to Check for Mirrored Elements Using this Add-in
  • The above add-in was removed as of Revit 2021 and was replaced with Model Checker under BIM Interoperability tools. It is basically the same but with a different user Interface. (See GIF below on how to Check for Mirrored Elements using Model Checker)
You can download both from your account management products/updates or Autodesk Desktop App
Nachricht 5 von 5
wezpb
als Antwort auf: RDAOU
Perfect thank you.
