Can we show something like these lights in revit?
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
368 Aufrufe, 8 Antworten
https://www.archdaily.com/902277/s-walt-disney-concert-hall-will-be-lit-by-algorithms-in-dream-like-...
and I don’t mean applying a bunch of materials, I would like to show as these projection lights with bright reflections, so the building elevations will become as a screen
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: Anonymous
What about a Self Illuminating Material?
Nachricht 3 von 9
aRcHiTeCt.JM
…hi @Anonymous
…. well … yes and no… maybe
… * it is possible for a static image
… it will be hundreds of spotlights all around and in so many directions
… I guess it will be a super difficult task
… and yes you can project to any surface spotlights
… you just need to make a lot of spot families with lights showing what you want
… something like this:
… spotlights with the design you like / need / want
…. showing projection lights
... this is one of the best ways to show projection / reflection lights
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Nachricht 4 von 9
als Antwort auf: barthbradley
thank you, I understand, we already tried something with materials but the most complicated issue is that we will need to apply like thousands of materials into the surface. so no. and the surface we are making is smooth we don't want it showing "broken" in a million pieces
thank
Annabelle
Nachricht 5 von 9
als Antwort auf: aRcHiTeCt.JM
thank you, yes , I am looking for something like these lights. it is nice because you can see the projection of the lights
this is a great idea
thanks
Annabelle
Nachricht 6 von 9
opps I forgot Verlegener Smiley
can I have those spotlights as you called them please?
to see how they were made
thanks
Annabelle
Nachricht 7 von 9
aRcHiTeCt.JM
... hi @Anonymous
....here are the spotlights
.... you can edit them to any shape you want to project in any surface
.... or at least see how there were made to try to make more
aRcHiTeCt.JM
REVIT EXPERT ELITE
Nachricht 8 von 9
thank you very much Lachender Smiley
Annabelle
Nachricht 9 von 9
Here'is an example using a material.
