Can we export number of Schedule at once?
12 ANTWORTEN 12
Nachricht 1 von 13
sureshchotrani
3246 Aufrufe, 12 Antworten
I have 12 number of schedule under views, is there a way to export all at once like we do to export sheets in CAD format?
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
12 ANTWORTEN 12
Nachricht 2 von 13
HermanSolomon
als Antwort auf: sureshchotrani
By default, no. However, there are a few add-ins available throught the exchange website that will be able to batch export schedules. ScheduleSync is one of them if I remember correctly
http://revitrecess.blogspot.com/
Nachricht 3 von 13
als Antwort auf: HermanSolomon
Nope, ScheduleSyncPro only exports excel files.
Nachricht 4 von 13
L.Maas
I use Dynamo to extract data and export them Excel or CSV files
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 5 von 13
als Antwort auf: L.Maas
How?
I've tried Dynamo and can not find away to export a schedule as a .txt file.
I don't want to export data, I want to export schedules. Because anyone without coding experience can create them.
I want tab delimited text files so I can import them as data into an excel spreadsheet, because then the data automatically updates whenever the excel file is opened.
Extremely simple and robust workflow that requires minimal software expertise from users.
The only problem l have is schedules have to be exported one at a time. Not even a keyboard shortcut works.
Why are the simplest things the hardest to do in Revit?
Nachricht 6 von 13
Keith_Wilkinson
als Antwort auf: Anonymous
maybe I'm missing something here but Revit natively lets you export schedules as tab delimited txt files...
"Give a man a fish and you feed him for a day; teach a man to fish and you feed him for a lifetime."
Maimonides
Nachricht 7 von 13
L.Maas
als Antwort auf: Keith_Wilkinson
Keith, the question was all at once. The export schedule will allow you to export a single schedule at a time only.
Louis
Nachricht 8 von 13
Keith_Wilkinson
ah gotcha. So actually the simplest of things in this case then Revit does fine... ;o)
Personally I prefer my schedules exported as Excel files as generally I find them much more useful but I guess it's horses for courses.
Maimonides
Nachricht 9 von 13
David_W_Koch
@Anonymous wrote:
How?
@Anonymous:  Have you seen the latest reply to what I assume is your post in this thread over in the Dynamo forum?  I have not had a chance to try it out yet, but the Python script looks sufficiently simple that even I can understand it.
EDIT:  I was able to get it to work for a single schedule.  I need to get back to paying work right now, but will try to work out the code to get it to export all of the schedules in a Revit project.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Nachricht 10 von 13
David_W_Koch
als Antwort auf: David_W_Koch
I took some time to look at this today, and was able to modify the Python Script that Dimitar Venkov posted, so that it will work with a list of schedules, and then came up with a graph that generates that list.  The attached DYN file was done in version 0.9.0.3067.
David Koch
Blog | LinkedIn
Nachricht 11 von 13
Thanks David, works a treat.
I started creating my own with Dimitar's code but you beat me to it.
Searching all the different Revit forums this functionality is asked for a lot.
I'll close this post and put the results of my efforts on the Dynamo forum.
Nachricht 12 von 13
Find more Dynamo solutions in the Dymamo forum:
http://dynamobim.org/forums/topic/export-schedules/
Nachricht 13 von 13
To batch export multiple schedules as multi-page PDF (or print), one can use the app Reports that is in the Autodesk App Store.
Luis Santos
archi systems as
