Can we create one revision sequence that is hidden on one sheet but is shown on the other sheet?
pmdewi
pmdewi
Hi, I am currently working on Revit 2022, and the revision sequence is using "Per sheet".
For example :
Sheet1 - rev01, rev02
Sheet2 - rev01
Sheet3 - rev01, rev02,rev03
The problem came when on Sheet1 & Sheet3, I need to hide the rev01 cloud, but on the sheet2 I have to show the Rev01 cloud. When I go to "Manage Revision" and change the Revision Cloud of Rev01 to "none", Revit will hide the the cloud bubble in the Sheet2 as well.
I need to keep all the revision sequence in the table, but only shows the latest revision cloud.
Thank you very much
jay_colcombe
It does sound like you require the sheet option.
You do have the option in the Sheet directly from the Properties Palette to Choose what Revisions is show on the Sheet
Jay Colcombe
Autodesk Certified Instructor
pmdewi
Hi, thank you very much. Yes I have tried that, and it works. Thank you once again.
