Can we change the size of temporary dimensions?
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
469 Aufrufe, 5 Antworten
Hello
Can we change the size of the temporary dimensions?  How?
I want to make them bigger so I can read them.
Nardo
5 ANTWORTEN 5
Nachricht 2 von 6
loboarch
als Antwort auf: Anonymous
No.  The size of temporary dimensions is controlled at the system level and there is no user control afforded.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Nachricht 3 von 6
cbcarch
Travel at your own risk:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 4 von 6
loboarch
als Antwort auf: cbcarch
New one to me. I did not know there was an INI switch for this.
FYI. Looks like 20pts is the maximum for the setting.
Jeff Hanson
Revit Help |
Nachricht 5 von 6
I did have to do a search for the file.  It is hidden in Revit 2018.  But is shows up when I searched for it.
Nachricht 6 von 6
FAIR59
no need to go hunting for the ini-file !!
Find the Options under the big Revit R,  on the [Graphics] page you can change the size of the temporary dimension.
