Can wall tags have an additional case based parameter for fire rating?
2 ANTWORTEN 2
Nachricht 1 von 3
dcsank
276 Aufrufe, 2 Antworten
I've noticed you can only tag a wall type with one name. Is it possible to make a case based additional parameter for fire rating?
2 ANTWORTEN 2
Nachricht 2 von 3
hmunsell
als Antwort auf: dcsank
you can make a Project Parameter and assign it to "Walls". it will show up on all walls n the model. the project parameter can be made from a Shared Parameter so it can be Scheduled and used in tags.
https://help.autodesk.com/view/RVT/2021/ENU/?guid=GUID-24033B80-62D4-4E04-AC15-FA8A6194A64F
Howard Munsell
Nachricht 3 von 3
I would create different wall types for different fire ratings.  Their assemblies are different and different types make it easier for tagging and showing fire tapes.
