Can topos be created from lines?
Hello
In Revit 2019, Can topos only be created by points, one at a time, or is there a way to use lines?  Please understand that using a CAD to make the topos is not available.  I only have an image underlay to work from.  The topo happens to have very many, in and out, wiggly lines.  Using the points along the topo lines causes the interior of the curves to fill in.  Then I need to go back and retrace the lines to trim those area back out.  It's double the work.  If I can make the topo from lines I can just trace those lines once.
Any recommendations on this?  FYI I am not AutoCAD fluent, so please refrain from recommending that I learn Civil3D to do it.
Nardo
Points can snap to Ref. Planes.
…"Wiggly" Lines? You mean Contour Lines?  Out of curiosity, why is it necessary to create a Toposurface?
bin
Maybe just add more point and try to place the points of different elevation side by side.
@Anonymous wrote:
Hello
Nardo
How "not fluent" with AutoCAD are you?  Can you insert an image, scale it, trace over with polylines, and select the polylines and change their Z to the correct values?
