Can't use selection box on a Linked Revit Model
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
tlagardeAJBTA
504 Aufrufe, 4 Antworten
Good morning all, I just realized today that it's impossible to use Selection Box on a Revit Linked file.
Is there a reason for that limitation ? Could it be solved by a hotfix ?
Process= Link Revit model
Select Linked Revit model
Try to do a selection box
Blocked/Failure
Thanks for any help
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: tlagardeAJBTA
Crop the Plan View around that specific area, go to 3D View and Orient View to that View and then select the Section Box and change its top/bottom extents.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Revit-D...
Nachricht 3 von 5
tlagardeAJBTA
als Antwort auf: barthbradley
Thanks but that's a work around, a long one. Autodesk needs to let us do more things with Linked Revit files, I just realized that you can't change the transparency either. We need to ask for more functionality.
Nachricht 4 von 5
https://forums.autodesk.com/t5/revit-ideas/idb-p/302
Also, if you are trying to create a section box of a wall (or anything that can be created parts from), then create parts then create section box of the selected parts.
Nachricht 5 von 5
What's stopping you from asking?  Go over to the Ideas Forum and start a new Thread. If it garners enough votes, maybe Autodesk will put on the Roadmap for a future release. Maybe you'll see it by 2025, 2026, 2027? In the meantime, workaround will have to suffice.
By the way, the "workround" is 2 steps. Maybe you misread it?  Orient 3D View to View and adjust the extents of the Section Box.  5-seconds tops, including coffee and bathroom breaks. :zwinkerndes_Gesicht:
