Trying to remove the line between these 2 walls which are of different depth. I tried using the join tool but it won't let me select the other wall. How should I remove the line?
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Are they Joined now (e.g. via Join Geometry)? If so, press the Align Command in that 3D View and then select both walls. That fix?
