Can't upgrade a file from Revit 2015 to Revit 2017
Hello Guys,
I have a problem, that I can't upgrade a file for a project from Revit 2015 to 2017 because of some corrupted groups in the original file, I tried to audit the file and fix it, then to upgrade it, but it's not working, can you help me please, you will find the file in 2015 version attached.
ennujozlagam
@Anonymoushello, try to clear all the warnings first in revit 2015 before upgrading to Revit 2017. Or to delete all errors when opening in Revit 2017. thanks
Problem 01.jpg Hello ennujozlagam, I have tried both solutions without any results, I cleared the warnings and upgraded the file, after I it asked me to delete the courrpted elements, I click on OK, then it gave me an unrecoverable error has occured, then it shutdown.
ennujozlagam
@Anonymousyes youre right same experienced here. your file is corrupted. If you are under subscription try to send to autodesk technical support they can help you to recover your files. sorry, not much help i can do. thanks
2015 -> 2016 -> 2017
