I added a curtain system and generic model that defines the faces to a design option.
Now I can no longer use the "update to face" button, it is greyed out.
When I click the generic model, it does show that the curtain system is a related host.
i'm having this problem in the main model too.
if I adjust the generic model, i lose the ability to update to face or edit face selection.
what causes that?
This happens to me all the time. I feel like you only get like 3 chances to update to face in Revit. (not true)
Is the original mass it's hosted to changed in any way? Even the slightest line added to the mass extrusion will be enough to decouple the face/mass connection.
Is it deleted and recreated? Therefore needs to be recreated by the curtain wall tool? Unfortunately I don't believe it can be rehosted.
Can you go back to an earlier version it was working in and re-copy that back into this project file? (mass + curtain wall)
I just have same issues, then I astonishingly find a solution
you just have to pin the curtain wall, and then unpin it. This makes the 'Update to Face' option appear in color
