I made a sloped curtain wall from a massing face. I am unable to tag it in plan or elevation but it does highlight single curtain panels for tagging. What do I gotta do?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Are you trying to attach a Multi Category Tag or a custom Roof Tag? What's happening exactly?
...is the category turned on?
A curtain wall is tagged correctly right next to this curtain wall in the view. I can not pick what kind of tag I use before tagging something unless I go to tag all which I did try with a multi-category tag, but it didn't work.
It should be a curtain system, not a curtain wall. And you should use a Curtain System tag, not a Wall tag.
I'm still not following your issue. You said you "can't tag sloped curtain wall", but here you say you did. A sloped curtain wall is of the family "Roof", so tag it with a Roof Tag. Does this not work for you?
Okay but I still can't tag it. The only selection I get is for individual pieces and not the whole thing. Let me clarify that there is a curtain wall that's not sloped next to it tagged properly.
My apology. There is no such thing as a Curtain System tag.
You can tag any curtain wall with a wall tag but you cannot tag a curtain system (which you are referring to as a sloped curtain wall) because they are different category altogether. You can turn on the mass surface used to create the curtain system and tag it using a Mass tag.
i think you can use keynote to tag it or make generic annotation having the desired tag text or tag the panels it self
