Can't tag area in an area plan
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
hliS658H
224 Aufrufe, 1 Antwort
I  created an area plan (Gross Building) for a mezzanine level, unchecked "apply area rules", I manually drew the area boundaries, obviously, two walls are interior walls instead of exterior walls. I tried to tag the area, nothing happened. Not sure about the reason, but suspect if this is because of used exterior walls? How to fix it?
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: hliS658H
You need to place areas in order to tag them.
