Can't start Revit: Loading GrphOGS3 library fails
1 ANTWORT 1
Nachricht 1 von 2
321 Aufrufe, 1 Antwort
I can't start revit.  I'm running the new update 2018.3 and when the splash screen is up i get a blank popup and when it's closed, the process dies.
This is what's in the journal file:
' 0:< DBG_INFO: Loading GrphOGS3 library fails.: line 75 of D:\Ship\2018_px64\Source\Foundation\Utility\Managers\OptionalFunctionalityManager.h.
' 0:< DBG_WARN: Fail to create TaskDialog from file. Object at key is not TaskDialog: line 62 of TaskDialog\AdWindowsTaskDialog.cpp.
' 0:< DBG_WARN: Create TaskDialog from file failed.: line 62 of Dialog\ATaskDialog.cpp.
' 0:< TaskDialog ""
'CommonButtons : Ok
I see why the popup is blank.  There's no info in the TaskDialog.
I've uninstalled and reinstalled several times, deleted all directories and deleted keys from the registry for a clean install.
1 ANTWORT 1
Nachricht 2 von 2
rbinning345
als Antwort auf: Anonymous
I'm seeing this same behavior on Revit 2017 since 4/13/2019
