Can't set the time in Sun Settings
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
1871 Aufrufe, 10 Antworten
Dear fellow Revit users,
I can't adjust the time of the day in any of my Revit files. It was working fine then suddenly the time disappeared, as you can see in the screen shot. I've already reinstalled Revit and that didn't fix it. Any idea what could be causing this?
Thanks!
Rafael
10 ANTWORTEN 10
Nachricht 2 von 11
RevitRx
als Antwort auf: Anonymous
is the time blank for the solstice and equinox presets?
www.RevitRx.com
Nachricht 3 von 11
JoshEKing
Is it possible to manually enter a time? Or is the field completely disabled?
Nachricht 4 von 11
als Antwort auf: RevitRx
Yes, blank in every possible date option :enttäuschtes_Gesicht:
Nachricht 5 von 11
Your View have the right Visual Style?
oops. Didn't see screenshot.
Nachricht 6 von 11
als Antwort auf: JoshEKing
The field is completely disabled, I can't type into it.
I opened the file on another machine and it worked there, so it must be some local setting. I also tried reinstalling Revit, no luck so far...
Nachricht 7 von 11
JoshEKing
Do you use Daylight/Summer time?  I'd be curious to see if your system's time settings had something to do with this...
Nachricht 8 von 11
Did you install any Add-ins recently?
Nachricht 9 von 11
Are you saying this phenom is affecting EVERY view in one Project, and that it is not just one corrupted view?
Nachricht 10 von 11
I wasn't using Daylight/Summer time, but when I went into Date&Time settings in Windows I noticed that the format was set to English (Europe). I changed to English(US) and it fixed the problem! Thanks for the hint :leicht_lächelndes_Gesicht:
Nachricht 11 von 11
als Antwort auf: barthbradley
It was affecting every view and every file! Finally I found out that changing Date&Time settings in Windows fixed it.
