Can't select using window
4 ANTWORTEN 4
Nachricht 1 von 5
spinckney
1820 Aufrufe, 4 Antworten
Help,
I am using Revit Architecture 2014 and drawing in a multi-level floor plan.
In one of my views I am unable to select families in my furniture workset using a window (in either direction).I am able to select my furniture families individually (but it's getting to be a pain).  I have checked that the furniture families are all associated with the current level. I can select these same families using a window in other plan views. I also find I am able to select other architectural objects and detail items using a window in this plan view.
What's happening here and what do I do to fix it?
Edit: and if anyone knows how to move this to the Architecture forum...not sure how I got kicked into this one.
4 ANTWORTEN 4
Nachricht 2 von 5
chrisplyler
als Antwort auf: spinckney
Your furniture is either on an underlay in that view, or your view's discipline setting is one of the MEP disciplines, or some other reason I can't think of right now.
Nachricht 3 von 5
chrisplyler
Oh, or... maybe they're within the view range DEPTH but not within the view range BOTTOM.
Nachricht 4 von 5
cholden
Did you ever get an answer to this? I am having this exact issue right now with a generic model family.
Nachricht 5 von 5
richardc
als Antwort auf: chrisplyler
:Gesicht_mit_rollenden_Augen:Brilliant , had the same issue Revit 2019, Post much appreciated
