Can't select anything
3 ANTWORTEN 3
Nachricht 1 von 4
5060 Aufrufe, 3 Antworten
I think I've accidentally clicked something that caused my plan to freeze up. I can no longer select anything. Additionally, the commands are grayed out too. How can I fix this?
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
You are creating a Floor but the context panel is not showing for some reason. Click on the double arrows at the far right of the ribbon see of you can reveal the Floor | Modify panel.
Nachricht 3 von 4
Try to change your resolution on your screen so you can see the entire Revit window...the Modify Tab is not visible.
Nachricht 4 von 4
cbcarch
Make sure Lines are turned on in VG--if turned off, you won't be able to see the sketch lines for the floor you are creating.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
