Can't see range hood
info
info
Hi
I can't see the range hood in plan view, please see attached.
I've checked the hood is correct phase.
rxi.gg
The view range is cutting the family or upper? If yes, check the visibility of the family, as in the other thread you just have opened
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
@info wrote:
Hi
Because it is above the view range.  There are multiple ways to show depend on how you want to show it (i.e. dashed lines) and how the family was created.  Share it here.
info
My apologies,
it was not the family. My boss put a "Plan Region" over kitchen area. When I pull it back I can see the hood!
