Can't see Plugins that I Downloaded
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
1887 Aufrufe, 4 Antworten
Hi there,
I've downloaded a couple of plugins, BIMobject and Enscape, and after installation these plugins don't appear on the menu bar. Am I missing a step?
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
Did you download AND INSTALL?
Nachricht 3 von 5
syman2000
What version of Revit are you using? Enscape Revit 2021 won't be out until June. When you install it, most likely it is installing for the older version of Revit.
Nachricht 4 von 5
als Antwort auf: syman2000
Ahhh I see, so I’ll need to use an older version (2020?) or revit for enscape to work? I also tried to download BIMobject and it too wasn’t showing, similar case right?
Nachricht 5 von 5
syman2000
Yes. On their website the latest version they support is 2019.
https://info.bimobject.com/help/revit
