Can't See My Annotations?
liz.nahm1
Message 1 of 8
liz.nahm1
I have two working floor plans for a project/course tutorial and I cannot see my annotations specifically section markers on the 1st floor only.  I am not aware of doing anything different with the 1st floor, but cannot see what I need nonetheless.  The section markers are not hidden in that view, I have tried to reveal hidden elements & there is nothing there.  2nd Floor looks just fine. Everything is visible on my Architectural 1st Floor Plan, which is the cleaned up pretty version. See image. Any ideas appreciated:\
Replies (7)
Message 2 of 8
https://www.ideateinc.com/blog/2013/01/missing-something-in-revit-view-33
My guess is that it's Phase related.
BTW: those are not "Annotations". Annotations though, are View-Specific.
Message 3 of 8
Lachlan-JWP
Your views are at different scales. Check this property for your sections.
Message 4 of 8
ennujozlagam
check your extents and adjust and see if helps. thanks
Message 5 of 8
liz.nahm1
"hide @ scales closer than' does not display on my Properties Palette & I cannot locate it on any of my plans.  Is this b/c I am using LT?
Message 6 of 8
liz.nahm1
Yup, I noticed that & checked both.  No change see image in my last response regarding 'hide @ scales coarser than'
Message 7 of 8
liz.nahm1
The view scale was the issue.  Thank you for noticing that!  I noticed that the were 1/8 v/s 1/4, but thought is was just telling me that I was zoomed in farther on one than the other. I went through an exhaustive search of VG, Hidden by scale of view(not displayed as such, but apparently still the issue!), Phase of view, Discipline & Crop region.  None was the issue & I had a suspicion it was something little, but did not have the depth of knowledge to know what it might be. Thank you!
Message 8 of 8
Lachlan-JWP
To see that property you need to select the section or elevation view, not the plan view. Glad to see your issue is fixed.
