I can't see my 3d model when working in Revit. Other 3d views will work but not the main 3d one. All of my sheets show up as well. Please help!
Is the View Phase set correctly?
I'll bet you a buck that one of these 33 will resolve this issue:
Missing Something in a Revit View? 33 Steps to Find Stuff | Ideate Inc
Try this:
Select elements by starting a selection in the top right corner to the bottom left corner of the view, anything selected...(see properties panel)?
Could be elements are placed (or by link) at a large distance from eachother making them so small they can't be seen.
Have had it a couple of times with dwg links with a element over 200km away.
solution unload/hide links and zoom extend and see if anything shows up...
- Michel
