Can't see doors while inserting into floor plan
Sahay_R
Mentor Mentor
Sahay_R
This has been going on since yesterday. Our old and trusty template suddenly stopped showing the doors while inserting and after insertion. I can see the doors in the 3D view, but in plan all I see are the openings. I can't select, edit, or delete the doors. I can insert Windows and Curtain Wall openings successfully.however.
View template - the same as what was used in older projects where doors worked successfully. In the View Template - Doors and its subcategories are checked. All the doors that I have tried work successfully in older projects as well as in the OOTB template. Something has happened over the last 24 hours that is creating mayhem. I have attached a file for your edification and entertainment.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Check your filters.
...I simply removed the template and all the filters from one of the floor plan views -- and doors appeared.
Sahay_R
THANK YOU!! IT was one particular filter that started running wild all of a sudden. Bad filter BAD FILTER!!
Rina Sahay
