We consult on a lot of projects in BIM 360.
We always have a hard time seeing curtain walls when they're used as interior office walls.
I have Curtain Panels, Curtain Systems, Curtain Wall Mullions, all turned on. Their sub-categories are all on. Walls are on. Doors are on.
I can see the doors in the curtain wall.
If I turn on Reveal Hidden Elements, I can see the curtain wall.
I can't figure out where they're being hidden in my View Templates or elsewhere.
Any ideas?
Gelöst! Gehe zur Lösung
Gelöst von Mbruno-JDB. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Any ideas?
When you select the hidden elements in Reveal Hidden Objects mode, aren't you given an option to unhide them on the Reveal Hidden Element Contextual tab?
Check you view's filters. If the curtain panel is a custom family then check for nested family's category.
Did someone just manually hide them? Can you right click them in the "show hidden" view and click unhide in view?
So change the components from specialty equipment to generic or curtain panel category. Using specialty equipment category for those us odd anyways.
@Mbruno-JDB wrote:
They're in a linked architect's model in BIM 360. If they were in my model I would.
Then you can create a filter hiding Specialty Equipment based on Type or Type Name or any parameter that only unique to the family and keep the category visible.
