can't see columns
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
2602 Aufrufe, 1 Antwort
can't see columns
when I try to add columns in my Plan I get the following message:
"" I None of the created elements are visible in Floor Plan: B1 View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings.""
when I go to the Elevation Plan; I can see that it was created when I point to its location
so the issue would be something in my view settings, But I checked my view settings and things looked OK!
1 ANTWORT 1
Nachricht 2 von 2
ennujozlagam
als Antwort auf: Anonymous
hello, when you want to add column use height instead of depth. check also your view range. thanks
