Hello all,
I have kind of a big problem with a project I am working on.
I was working on a project in revit 2018 without being signed in, i then opened a project in revit 2020 in which i need to log in for.
This also logs you in to autodesk on revit 2018 which I didn't notice. I made changes in both projects and at the end of the day I tried to synchronize my project but it wouldn't let me do that because the local file was made with a different username.
Revit prompts me to look at the workset dialogue but that just gives me the same error.
When I try to "save as" I again get the same error which dissalows me to do this because my username is incorrect.
When I try to change my username I get the same error.
Is there any way to salvage my work? It seems like it is stuck in a loop.
In short:
Can't save project because username doesn't match
Can't change username because changes were made with different username.
Cant synchronize because username missmatch
Can't save as different file because of the same username problems
Can't look at worksets because username doesn't match.
Help me obi wan, you are my only hope
